CBR Performance
CBR Performance - Official UTVUnderground Sponsor
CBR PERFORMANCE PRODUCTS inc. has released its new polaris rzr 800/800s oil cooling kit. This kit features the latest and greatest in high performance cooling technology. CBR PERFORMANCE PRODUCTS revolutionary turbulized design universal plate and fin oil cooler is made of an aerospace quality aluminum construction that allows the cooler to be lightweight, compact and rigid while offering a high heat transfer and extremely resistant to corrosion. The unique internal turbulized fins with the plates maximize heat transfer and redirect the oil flow, which works with the airside louvered fin design to provide highly efficient cooling with low pressure drop. The cooler mounts on a supplied bracket behind the radiator while a new oil filter bracket relocates the new wix filter on the front fire wall for easier oil changes. Oil temperatures have been seen dropping as much as 40 degrees in the most extreme climates. If you have a big bore kit, turbo, or just want your rzr to run cooler, this kit is for you!! two different size coolers are available (10 plate, 20 plate).Comes with all necessary hardware to install kit. Call today to order yours!!!
CBR PERFORMANCE PRODUCTS INC. HAS RELEASED ITS NEW POLARIS RZR 800 STAGE 1 COOLING KIT. THIS KIT FEATURES THE LATEST AND GREATEST IN HIGH PERFORMANCE COOLING TECHNOLOGY. WHAT GIVES THIS REVOLUTIONARY RADIATOR ITS EDGE IS THE CORE DESIGN, FEATURING AN ADVANCED 6.6mm FIN PITCH AND 42mm THICKNESS, COMPARED TO THE STOCK 10mm FIN PITCH AND 28mm THICKNESS. THIS ADVANTAGE ALLOWS FOR A LARGER SURFACE AREA FOR SUPERB COOLING PERFORMANCE. THE CUSTOM BUILT TANKS ALLOW A MASSIVE 20% GAIN IN COOLANT CAPACITY, AND FEATURES OUR DUALPASS DESIGN WHICH ALLOWS THE FLOW OF COOLANT TO PASS THROUGH THE CORE TWICE INHANCING THE COOLING CAPABILITY. THIS KIT IS A DIRECT REPLACEMENT, UTILIZING THE STOCK FAN AND SHROUD. THROUGHOUT TESTING, TEMPERATURES HAVE DROPPED AS MUCH AS 30 DEGREES IN THE MOST EXTREME ENVIORMENTS. DON’T LET THE HEAT SLOW YOU DOWN. THIS KIT IS 100% ALUMINUM AND 100% TIG WELDED FOR A LIGHT WEIGHT AND DURABLE CONSTRUCTION. CALL OR EMAIL FOR MORE DETAILS. TO MAXIMISE YOUR COOLING PERFORMANCE, ADD A CBR RZR OIL COOLER KIT TO YOUR ORDER.
