Throw Rocks, Mud & Snow with Pit Bull Tires®
Rock Beast® II 2.2 R/C Tires
St. Louis, MO (1/18/13) - Pit Bull Tire's Rock Beast® II Scale 2.2's are miniaturized versions of the Champion Pit Bull Rocker® Light Truck 1:1 tires. With attention to every detail, these dirt crushing, rock gripping, and snow flinging tires are like no other 2.2 Scale R/C tire.
Rock Beasts have many design features to increase speed and control while enhancing stability and contact patch. The multi-varied tread design increases forward/reverse and lateral traction with serious biting across the footprint.
Pit Bull's championship winning Komp Kompoundâ„¢ has proven to provide incredible stickiness, durability and rock-grip traction while playing or going for the podium finish.
Did we mention that the RB II's are TALLER 2.2 tires?!!! You asked for it, and now the 5.75" mounted diameter* tires have been sized by the people, for the people.
Features:
Komp Kompoundâ„¢ - the only compound we are using on these bad boys. They seem to get better and better as they break in... and you can use them for your daily hobby time as well as competition... RIGHT OUTTA DA BOX!!!!
Stepped Lugs - aid in lateral traction
Multi-Varied Tread Blocks - create an alternating biting pattern for maximum traction, especially in off-camber situations
Inside Ribbing - provides sidewall support and stability
Integrated Sidewall Protectors - sidewall bands of rubber that add support and control
Over-The-Shoulder Lugs - wrap down the sidewall and add extra strength & traction to the shoulder & sidewall areas
5.75 inch Mounted Diameter* - nice and TALL, just what you've been asking for!! *Dimensions may vary depending on mounted rim used.
No Foam - sorry, not this time. We put it out to a vote and the majority of people said, "No thanks, save us the money."
Part# - PB9002NK PIT BULL® Rock Beast® II Scale 2.2 R/C Tires
(2) Two Tires per package & (1) Decal sheet.
Tire Specs:
Komp Kompoundâ„¢
2.2" Rim
2.22" OW*
5.75" OD*
Weight - approximately 5.2 ounces per tire (without foam)
For more information call 800-645-2006 or visit www.pitbulltires.com for your nearest dealer.
