Odyssey Charging problem
talbert450r
When I went to start the rhino I found that the battery was dead. I made several attempts to charge it with a charger specified for AGM/Gel Cell batteries. The best I can get is 10.5 V but it is not enough to crank over. I jump started it and went on a 2 hour ride and when running I have a message on the digital display that says "HI-Voltage" it shows that the voltage is 17 V. But even after running for 2 hours the battery was still dead. Why would I have High Voltage with a bad battery?
