My Dream Build
Yes they will.. Johnny and Willey are really good guys and make some nice stuff..
Cant wait to see in person.
Updated Build Sheet...
New Silver LE XP 4 with EPS converted to a 2 Seater with Turbo'd Apex Power 400 HP Dream Machine...
UTVINC Custom Cage with (2) Grab Handles & (3) Tab Mounts & 40" Rigid LED Light Mount
UTVINC 1 Piece Roof
UTVINC Etched Carbon Fiber Roof Liner
UTVINC Fire Extinguisher
UTVINC Doors (2) doors open and solid rear panels
UTVINC Etched Carbon Fiber Door Liners
UTVINC 5 pt. Harnesses
UTVINC TS Heated Seats
UTVINC Seat Lowering Bases
UTVINC Custom Engraved Switches
UTVINC Auto Meter C 2 Gauges
UTVINC HD Tie Rods
UTVINC Parking Brake
UTVINC Sun Visors (2)
UTVINC Quick Light Fiber Optic Whips (2) Red
UTVINC 40" Rigid Series E LED Light
UTVINC 1 pc. UHMW Skid Plate (full coverage)
UTVINC Full XP Gusset Kit
UTVINC Parker Pumper
UTVINC Radio Stack Rack
UTVINC G-Force Helmets (2)
UTVINC Rugged Radios 50 Watt with 686 Intercom & OTH Carbon Fiber Head Sets
UTVINC Rugged Radio Helmet Radio Kits (2)
UTVINC Trailing Arm UHMW Sliders
UTVINC Steering Column Wobble Delete
UTVINC Steering Column Extension
UTVINC 60 amp Distribution Box
UTVINC Optima Battery
UTVINC Optima Battery Box Conversion Kit
UTVINC Oh-Chit Anti Rattle
UTVINC Bed Heat Shield
UTVINC LED Turn Signal Kit
UTVINC Fan Over Ride Kit
UTVINC Security Alarm
UTVINC (2) SKAT BUFFS Front Tires
UTVINC (2) SKAT 14 PADDLE EXTREMES Rear Paddles
UTVINC Billet Shifter
UTVINC Billet Shifter Handle
UTVINC Billet 1.25 Tow Hook
UTVINC Billet Grill
UTVINC Billet Air Intake
UTVINC Billet Clutch Intake
UTVINC Billet Door Handles
UTVINC Billet Custom Dash
UTVINC Billet Dome Lights (2)
UTVINC Billet Crazy Lights (2)
UTVINC Billet Headset Hanger
UTVINC Billet Radio Cord Mount
UTVINC Billet Rear View Mirror
UTVINC Billet Side Mirrors (2)
UTVINC Billet Key Fob
UTVINC Billet Tilt Handle
UTVINC Billet Cup Holders (2)
UTVINC Billet Fire Extinguisher Mount
UTVINC Billet Parker Pumper Mount
UTVINC Billet Custom Dash With Lowrance GPS Mount
UTVINC Custom Color Powder Coating
TAGTEAM APEX CONVERSION KIT
TAGTEAM OIL COOLER
TAGTEAM LABOR & $$$$
STM BILLET CLUTCHES
UMP Super Filter Long Air Box with 4" Inlet / Outlet and 4" Super Scoop
GNS Apex Custom Built Garrett Turbo with Anti-Surge, Polished Compressor Housing with Ceramic Coated Turbine Housing and 4" Inlet
GNS Apex JE Turbo Pistons
GNS Apex Carrillo Rods
GNS Apex Valve Springs
GNS Apex Head Studs
GNS Apex Fuel Injection Kit
GNS Apex Gasket Kit
COGNITO SHOCKS 2.0 Front & 2.5 Rears
COGNITO Sway Bar with Mounts
COGNITO Radius Rods
COGNITO A-ARMS with Uni-Balls (no weak ball joints)
COGNITO Custom Color Powder Coated All Parts
BMP Fabrication Custom Built 21 Gallon Fuel Cell with Quick Dump Filler Recessed Mounted
BMP Fabrication Custom Shock & Trailing Arm Mounts
BMP Fabrication Custom Interior Floor & Balk-Head Panels with Dzus Fasteners
BMP Fabrication A-B-& C Cage Mount Plates
BMP Fabrication Welded the Frame & Gusset Weld In Kit
Lowrance Baja Elite 5-m GPS
CBR Radiator (stock Location) for Air to Water Inter-Cooler
HOWE Racing Radiator (rear mounted in cage) 31 X 19 X 7.5 with Maradyne 16" Fan
HOWE Racing Aluminum Fan Shroud
HOWE Racing Billet Filler Neck
HOWE Racing Steering Wheel
Holz Billet Motor Mounts
Holz 300 M Alloy Rear Axles
Holz HD Front Axles
Holz Remote Oil Filter
Holz Front Upper A-Arm Gusset
NRG Quick Disconnect Steering Hub
Grant Steering Wheel
MIDWESTUTVCUSTOMS (5) Hiper Lite Dakar Duel Bead Lock Wheels 3 X 5 X 14" (Black & Machined Finish)
MIDWESTUTVCUSTOMS (5) Mongrel Tires 28 X 10 X 14" DOT Approved Tires
MIDWESTUTVCUSTOMS (4) Hiper Lite Side Winder Single Bead Lock Wheels 3 X 5 X 12" (Black & Machined Finish)
Racer Tech XP 4 Frame Weld In Gusset Kit (both kits for XP 4)
Racer Tech XP 4 A-Pillars
Updated list...
UTVINC 1 Piece Roof
UTVINC HD Tie Rods
UTVINC Billet Grill
UTVINC Billet Custom 1 Off Bed Heat Release Cover
TAGTEAM OIL COOLER
STM BILLET CLUTCHES
GNS Apex Head Studs
GNS Apex Gasket Kit
COGNITO Radius Rods
BMP Fabrication Liquid Filled Fuel Pressure Gauge
BMP Fabrication Rising Rate Fuel Regulator
BMP Fabrication EFI 75 PSI Fuel Pump
BMP Fabrication Stainless Fuel Lines
BMP Fabrication Fuel Line AN Fitting Kit
Lowrance Baja Elite 5-m GPS Cover
The "Machine Shop" Drive Shaft Alignment and Balancing
Holz HD Front Axles
I've been stalled on the Apex Build... Bought a motor home & new 8.5 X 20 enclosed trailer which has diverted my time... I'll be back at it soon as I have the motor home & trailer ready to roll...
