All UTV's Lowrance Elite-5M Baja GPS from PCI Race Radios **UTVUnderground EXLUSIVE**
Lowrance Elite-5M Baja GPS​
Lowrance just sent us this awesome new GPS out to us, the Elite-5M Baja. This thing is the cats meow when it comes to off road GPS Systems. We will be installing this unit into one of our Project UTV's and will also use it in our chase truck for race adventures. We will updated everyone on the install and our thoughts on the use of the GPS once we get a chance to use it.
If anyone has any questions let me know or contact PCI Race Radios to purchase one of these affordable units for your own UTV or off road vehicle!
Elite 5m Baja Kit GPS New! Detail Page
Specifications for Elite-5m Baja | Lowrance
Lowrance Elite-5m Baja Chartplotter​
Specifications
Feature-packed off-road GPS navigation with a brilliant, easy-to-view color display.​
DISPLAY
Display Size 5 in \ 127 mm
Display Resolution 480x480 (H x W)
Display Type 256-color SolarMAXâ„¢ PLUS TFT
Backlighting Flourescent cold cathode
Backlighting Levels Adjustable screen/keypad
Languages Supported 23
GPS / NAVIGATION
GPS Antenna Type Internal high-sensitivity WAAS + EGNOS + MSAS (optional external antenna)
GPS Receiver Channels 16 channels
Background Map U.S. basemap with over 3,000 enhanced lake maps with depth contour and shoreline detail, plus coastal depth contours/shoreline detail and spot depth soundings to 1,000 ft./305 m
Custom Mapping Optional Navionics® Gold chartcards (U.S. & worldwide) and Fishing Hot Spots® and LakeMaster® mapcards (U.S.) in microSD format
Waypoint Storage 3000
Routes 100
Plot Trails 100 retraceable plot trails/up to 10,000 points per trail
GPS Alarms Yes
NETWORKING / CONNECTORS
NMEA Output NMEA 0183
TECHNICAL / ENVIRONMENTAL
Built-in Backup Memory Yes
Waterproof Standard Sealed and waterproof, suitable for saltwater use
Width 6.9 in \ 174 mm
Height 5.4 in \ 136 mm
Depth 2.5 in \ 63 mm
POWER
Power Supply 10-17 vDC
OTHER
Memory Card Capable One (1) waterproof microSD card slot
Supposedly this unit does not need the additional $300 antenna you had to buy with the old units....
yep Waleed is right....It comes with both the external bitchin (little smaller in diameter) antenna and it houses an internal. So what I plan to do is install the external on my truck since the unit will be in the closed cab and then run the internal in the UTV since it will have a better sight line to the sky! We will see how it works.
So you have had this for a year now, what are your thoughts on it?
