LED Stixx 44" LED bar
I bought a 44" LED light bar to compliment my HID headlights and its bright! I had FU2Chassis weld on tabs on my cage when it was being built and I fabbed the light bar holder. I used 5/8", mild steel .060 tubing and bent it so it has about 1/2" further then the light so branched would hit that instead of the light to give it some protection.
Wired it through the cage.
It throws out 7.5k Lumens, has super large LEDs in combo of spot-flood-spot-flood and is made in the USA. Def a great upgrade if you are in need of more light at a cheap price. On the www.alpinesandtoys.com, they are listed for $560! You can get then as cheap as $200 for a 16" one.
