it will leak at the head if you go higher than 10lbs of boost or any amount of boost will cause this.sorry just want to make sureYou can spend a bunch of money on the 800 changing the crank and everything else but it will keep leaking at the head if you run higher boost. You could put a Z1 in the 800 and it would be fast and at least the engine would be reliable.
