Other FOX Shocks, add a Remote Reservoir?
Dose anyone in the Underground, know if a remote reservoir, can be added to a Fox 2.0 air shock? :confused:
On an emulsion shock, absolutely. On an air shock i'm not sure. I don't think i've ever seen any Fox air shocks with a reservoir. What are you trying to accomplish?
Higher oil volume and smooth out the pressure spike of the Nitrogen.
  • Fox 2.0 w: res.jpg
    Fox 2.0 w: res.jpg
I don't claim to be a shock specialist, but that pic looks like an emulsion shock. The air shocks i've seen usually can be identified by a much larger shaft diameter.
Have you called Fox?
Their was some talk about this on a minibuggy fourm awhile back and it sounds like back in the day it was a popular thing to do with the stadium buggys. Their where a few pics posted of older buggies with air shocks and a reservoir but no one had any first hand experience with it. I have thought about doing this my self. Remove the schrader valve from the shock and have a hose made to go from their to the reservoir and add the new schrader valve their.
A few things holding me back. I dont know how big to make a reservoir. I dont really know how it will affect the shock valving. I also dont know if the NTP thread where the schrader valve is on the shock would be a large enough size hole to transfer oil/nitrogen and work well.
Any one have any thing they can add to this?
I'm sorry but I don't understand why you don't just pick up the phone and call FOX! They are air shock experts! They make air shocks for off-road, atvs, and bicycles. They will know the answers you are looking for.
if an emulsion shock, the piston will have to change also, when the resi is installed.
I called today, but couldn't get through. I looked all through their web page again, just in case I missed something.
This post was a shot in the dark, to see if it had ever been done.
Thanks for the Info!
Their is a few guys on minibuggy.net running them. I was looking around today one guy just has a 1/2" ntp hose and says he has put a ton of miles on then with luck. I may try it at some point.
Hookemdevils22
