702sandman
has anyone hooked up a aftermarket spal fan to a 17' xp turbo stock harness ? When you hook up a regular spal fan to the stock connector the fan comes on automatically instead of coming on at the preset temperature. I'm thinking it must sence a signal from the ecu and just turns on. It's not a big deal we can add a relay and find the trigger from a temp sensor and make it work I was just curious if anyone else has ran into this ?
