engine die after starting
bulldogs101
2011 polaris ranger crew. 16 hours.
i worry about the little things or possibilities to much im sure, anyone have suggestions or no of issues.
always runs fine, no issues until today, while ridding in average trails, no step mountains, about an hour into ride, with clean new fuel. i stopped to rest. when i restarted it sounded and acted like it was just barely going to stay running.. give it gas and went on, ros have always been 1200.1250 rpm. this sounded like it was so close to dying that i thought it was going to.
move forward another hour after i returned to truck. shut it off and got trailer and thinsg ready.
now restarted polaris, it did die fully in about 2 seconds after starting it. gas is 3/4 fuel. i restarted again 2 more times and all sounded normal and correct. when i got home, restared 2 more times, no issues. it alweays ran fine, sounded fine while driving today.
just those 2 issues, but they could be a real issue. anyone know what coukd be wrong, if anything, is this normal????
i dont wantto go to a dealer, if you cant reproduce it they could not fix it anyways. anyone have this happen or know what to look for.
cant be plugs, fuel filter, bad gas, low battery, blocked air filter, because it run fine all other times, just the 2 starting issues, it did kick right over. just the almost dying issue, then dying the 2 nd time..
It could be several things, but your info is pretty vague for this meatball to offer up much help. My guess is that the idle is simply set too low or that the air filter is dirty. But in this case your dealer is probably your best friend. You don't have to take it to them, but call up and ask to speak to a tech. They can likely point you in the right direction. If you tell me where you live, I can suggest a good servicing dealership. :)
