BITD/SCORE Fuel cell Harmon/Pyrotect/other
Ratoutahell
Hey guys, Looking at getting a fuel cell legal for BITD/SCORE. I have found both Harmon and Pyrotect fuel cells. Pyrotect sells for $2600 and Harmon starts at $1900. Both 20 gallon capacity for 2-seater car.
I was curious if anyone can tell me the pro's and con's of either. I have generally found that cheaper is generally not better but curious what you guys are running. Any other options?
-Kyle
Im not sure of the type of fuel cell but I'm pretty sure Lonestar Racing sells one. You might call them for info.
Im not sure of the type of fuel cell but I'm pretty sure LSR sells one. You might call them for info.
Thanks, yeah LSR sells the Pyrotect fuel cell. Just curious what the difference is from the Harmon for the additional $700. I'll call them on Tuesday when they open if no one knows.
-Kyle
Harmon's quality is second to none. I can't recommend their products enough. They also build custom cells in any configuration that you can dream up.
Pyrotect has separate intank pump and collector box, must use an aftermarket return style regulator. Aftermarket fuel level sending unit.
Harmon's tank utilizes the stock fuel pump and hat assembly, which then uses stock wiring and plumbing, as well as the stock fuel level sending unit.
Thanks Bret. So I thought according to BITD rules the fuel system had to remain stock as delivered from the factory? Are aftermarket fuel pumps and regulators allowed?
Per BITD rule book:
UTV
15 FD FUEL DELIVERY:
Pro Production UTV class
The fuel delivery system must remain the same as the
stock system delivered from the factory."
Thanks, Kyle
Per BITD rule book:
UTV
Thanks, Kyle
There's a lot of rules that don't make sense in that book, but yes aftermarket fuel pumps are allowed. Up until Harmon came out with their cell that was your only option.
