Baja Designs LED Dome/Rock Light
Baja Designs NEW LED Dome/Rock Light
Baja Designs NEW LED Dome/Rock Light is extremely small yet 1 ½ times brighter than competitor’s larger 15 LED units. It is waterproof and can be mounted anywhere. It has a 360 degree optic to illuminate your cab, engine bay, wheel wells or anywhere you need a super bright, super smooth light!
“Amazingly clear, vibrant white light output. Quite possibly the brightest LED undercarriage light ever offered.â€ÂÂ
-Robin Stover
Feature Editor, Four Wheeler Magazine
It is available with or without an integrated switch and in tube mount or panel mount versions. If desired the tube mount versions can even be installed using a zip tie - no drilling required. Its simple two wire installation will have you on the trails in no time.
Baja Designs is a leading manufacturer and marketer of high-quality aftermarket lighting systems and adventure products for the off-road industry. Headquarters are located in San Marcos, California.
More info HERE: https://www.bajadesigns.com/NET/P-616080/Led+Dome+Light+W/+Switch
For more information and/or Hi-Res product photo contact:
Chris Chapman, Baja Designs Inc.
E-mail: Chris@BajaDesigns.com
185 Bosstick Blvd. San Marcos, CA 92069 Phone: (760)560-2252 ext.124
I installed one of these in my car and they are SICK! SUper bright and low draw. You can leave it on all day and not juice the battery. They look and work great!
I will get some install pics...
