Az Member needing help before GLAMIS
Dacarman
Hi guys I have been calling around trying to find an ignition coil for my rhino 660 (with no luck).... What I actually need I think is the spark plug wire (but I know they come together) My wire will not stay on the plug! So I was hoping that maybe someone has a spare one they could sell or something! We have a large group headed out to Glamis and I don't want to miss this trip! I'm in the Phoenix area and would appreciate any help or insight.... Thanks!!!!!
the wire might be able to unscrew from the coil and you can add a generic wire with new plug end. You can buy them at any autoparts store.
its been a while since i had a rhino so i dont remember what the coil looks like.
Take a thin flat bladed screw driver and look down inside the spark plug wire, you can tighten up the end of it and the wire should stay on after that.
Tatum, the spring inside the spark plug boot fell out does that make a difference? (I still have it but should it be that loose)
Yes,it makes a difference.The spring goes in the boot and then a little collar that fits over the plug screws in and holds the spring in.If you dont have the collar it is probably laying down in the head by the spark plug.
I will PM you my number in case you cant find one.I could loan or sell you my spare.
Yeah out of all that stuff pictured all I have is the spring! I'm guessing when I pulled the plug wire off initially they got lost since they are nowhere to be found! And thank you so Much I will call you in the morning...
