2010 rzr s
spowell
i have a 2010 rzr s that jerks in high and low when you take off but stops once you get moving does anyone have any suggestions?
Clutch is sticking or belt is stretched/slipping and needs replaced.
Otherwise it might be your throttle position sensor.
Do a diagnostic check per your owners manual and see if it throws a code
if so check the chart and see what it is.
dhakdhaki
