wheel width
slimp-o
Slimp-o
Just got a full set of skat track sand tires for my 2010 teryx. They are 26-9-12 up front and 26-12-12 just wondering how wide of wheel to get, also same width front and back?
How about 8 wide in front and 10 wide in back.
Sent from my SAMSUNG-SGH-I717 using Tapatalk
Thats what I'm running w/ 4/4 and 5/5 offsets works good for my XP900 especially wide open dunes like Glamis. If your running OR or tight dunes I'd give Dave @ FSS a call see what he thinks. He got me a good deal on rims, DWT reds.
I was looking at the hiper wheels. I like the looks of them but the widest I have found is 8". What is FSS? And whats the number?
Yeah Hyper is one of the strongest to weight ratio wheels on the market if you can afford them. There is a whole lot more to it than width, just as important offset can change the width positions in front and/or rear for stability for Glamis and drag racing or maneuvering through tight treed dunes like OR, or short tracks. 4/4, first # inside width to mounting flange, second outside, you could run 3/5 or 2/6 on a Hyper in back it’s strong enough, but a blue or red label DWT (Douglas Wheel) I’d question in racing applications @ .190 thick aluminum, but might be fine since they are roll forged and strong too. The offset can also add or remove bump steer, change the steering inclination, add or remove load from suspension components, but will not affect shock valves.
You might want to do some research and think about what it is you want out of your ride then call Dave @ Fullerton Sand Sports, 714-484-5996 goggle web site. He sent my play cut blasters and buffs to Seattle when I lived there although I’d prefer some bite like a Mohawk up front for up there, but my rims and offsets did fine. He’s in So Cal and one of the most knowledgeable in the world on tire and wheels combo’s, tell him TNT sent ya. Sometimes he’s hard to get a hold of keep trying.
Hope that helps and good luck!
