BlackRhinoScott
BlackRhino Performance & Alba Racing have got something NEW for all RZR XP1000 owners!
Did you know belt temperature is directly related to belt life? To make it as simple as possible your belt is made of rubber. The hotter it gets the weaker it gets.
This is a complete belt care solution designed for the RZR 1000. With this kit you get a belt temperature gauge that controls a blower fan. The gauge has a light to let you know your fan is running. Also the gauge will turn the fan on and off at any temp you choose. We typically have it turn on at about 140 degrees.
Features:
-Now tested and used by military (It works).
-Belt temp gauge with adjustable fan control.
-Gauge has led to let you know the fan is running.
-Gauge face is custom to match your OEM gauge look.
-Includes complete harness and relay pre wired (looks OEM).
-Includes big 240cfm blower fan kit with template for easy install.
Includes:
-Belt temp gauge with fan controller.
-240 cfm blower fan with couplers and clamps.
-Complete wiring harness pre wired with relay.
-Instructions and stickers.
-This is a complete kit that includes everything you need.
blackrhinoperformance.com/shop/best-sellers/polaris-rzr-xp-1000-belt-temperature-gauge-and-blower-kit-by-alba-racing/
www.blackrhinoperformance.com
And DONT forget about the BlackRhino Performance Dash Plates that can go right with the above gauge & switches.
blackrhinoperformance.com/shop/best-sellers/black-rhino-polaris-rzr-xp1000-side-dash-switch-plates-switch-and-gauge/
Features:
Includes:
