Front rhino hubs
Just curious what front hubs people are running. I'm currently running the stock ones and the driver side has started to wear the splines in side the hub housing. I know that the aluminum on the stock hubs are soft, but I haven't seen any upgrades? Any ideas??
I have 1000's of miles on my stock hubs racing all over from Texas to Mexico. Keep the splines lubed and the spindles nuts tight and you should be good.
Rob
The stock hubs are not aluminum....They are steel. You might have something aftermarket
Aspendell Rover we are not talking about spindles we are talking about hubs, if your not familiar with where and what the hubs are the outter Part that the rotor and wheels bolts too. The order goes like this; spindle which bolts to the upper and lower control arms then the bearings sets in the spindle then the snout slides into the spindle then the splined hub slides over the snout and then the rotor and wheel bolts to it.
