Yamaha Front Axle popping out
ParaPros Racing
parapros racing
I have the SDR long travel and my front right cv pops out of my front diff about 1/4 inch or so any have this happen ?
what can I do to fix it ? Brad
Check the c clip at the end of the axle it could be worn out from when the kit was installed or it could have popped off. Install a new clip and see what happens.
while you have the axle out make sure the CVs are clocked correctly . most likely its the C clip . but alot of people dont think about the clocking of the CVs and under extreme angle it puts them in a bind and can cause them to pop out.
good luck
Make sure the star in the cv is not backwards and check the location of the diff. The front diff mounts are really weak.
what its doing is when its all together I go to tighten the axle nut
it pulls the cv right out the diff almost as if the axle is a little to short I checked the axles and they are right so just not sure
thanks for the help
Brad
I agree with Court,make sure your frt diff has not moved because the mounts are weak.Also make sure the inner cv is plunging all they way in and out otherwise your axle is to short.
Blaster
