Polaris DIY XP1000 Steering wheel puller
CrawlerJamie
Here's how to remove the steering wheel nut in your xp1000.
Grab a couple of non stretch limiting straps, wrap around your CageWRX cage and steering wheel. Orient them so it won't bend your wheel. Connect them with a strong bow shackle. Grab yourself a nice bar and it'll come right off.
The RZR where was the easiest wheel I've ever removed. And I've removed dozens. I even had to make a puller.
Here's the puller I made
I made it out of angle iron so it wouldn't bend. (I was expecting this to be a fight).
The little bolts are 5mmx50mm metric. The center bolt is 3/8".
The small bolt threads into the 2 small holes in the steering wheel. The center bolt presses up against the steering shaft. Thread the small bolts all the way in. Thread the nut on the 3/8" bolt up against the angle iron. Put the wrench on the nut, and a socket on the 3/8" bolt head. Turn the bolt head clockwise and after 1/2 turn the wheel will pop off. Barely even have to put any force on the ratchet.
Total time invested - 1 hour
Total money invested - $10
