building a rzr 900 xp for worcs
azrider717
Im about to build a xp for the worcs pro class, what are some must haves? Lookingat the holz race kit, or what would you guys do? Also would a stock motor do fine in pro class or do i need to build it up? Thanks, cody
I ran my XP a few worcs races last season, and it was an awesome platform to work with, throw on a cage/doors, a good spring and shock package and if you want to drop money in the motor to try and run up front you can but keep it reliable.. we built some high clearance boxed arms that worked out well and the car was alot of fun. I would make sure you get some beadlocks as the Worcs series is an awesome gran prix style of racing. Also remember if your gonna build the car for worcs only, cut all the weight possible
IF you are looking to build a custom cage or need any help with sheetmetal or tubework let me know...
also have an arctic cat 1000 for sale for 10k if it interests you
So for suspension what you guys think about the hcr kit? Or is there something better out there? Also would a 975cc kit be very reliable?
HCR kit is too wide for WORCS in my opinion. I would keep it stock width. At worcs you need to be nimble, light, and be able to turn with ease as to not fatigue. You also need the balls to jump. No knock on HCR. The kit is sick but not necessary. I would stick with a beefed up stock width suspension. Like James said, try and save weight. That is key!!
I would agree with Joey on not going with the HCR lt kit cause the car does not need to be wider which will make your turning radius larger and you do not want that. Main thing I would do is try to cut as much weight as possible then you will not need motor work!
That's a good start for a light reliable car, a mild motor (head work, high compression pistons) can be done down the road when your able to out-drive what you have.
What they said. No need for a wider car. The Holz kit is awesome. I built two of those and raced WORCS full season. Holz product is top notch, light weight and clean. You don't need to add radios, pumpers, gauges, or any of that crap. Strip it. Make it safe, simple n run it. The stock motor is fine also.
O, and buy a good seat.
