AGM Shock Shaft Jaws
IxljdTBu4XK95EPwoVpHy4fpPlMZS1rdzBloGC39XN884BgMEEv73UNAvQj54WR_3ttJRYG8HvwkTB8x-LxRqZ4Q4HJcmWnuFewWIeFQcKbbnoLCgLIrVAqbD1YnSiSJdtcXsEzxWWEI2jOgUKhsh5-iRB5e2Gd7MyAw80c=s0-d-e1-ft
Parts Tools About Us
AGM’s Shock Shaft Jaws are designed to provide you with a quick and easy way to hold your shocks during service. And 360 degrees of smooth bore, non-destructive clamping force will ensure your shock's shaft will not rotate. No more damaged shaft during service and no more leaking seals as a result.
Made from high-quality 6061 aluminum, the precision machined design works in any vice or press and accommodates shaft diameters from .625in up to 1.25in.
$135.00
Order
Ronh
