Kawasaki 2014 Teryx2 Fox shocks, fit on Teryx4?
GunnTeryx4
Will the new factory 2014 Teryx2 fox shocks fit and spring rate the same as the Teryx4? Please help of you know the answer...
Sent from my SGH-T499 using Tapatalk 2
I know that shocks will fit now, but is the spring rate and the valveing the same?
Could be wrong but, heavier car usually ='s heavier springs and valving to control them. Sure you could dial them in to be what ever you want them to be. When you do think about how you will be running it weather it will be set up for two and occasionally four people or the other way around. Hard to tune a four seater to be perfect for all due to the large variance in laden weight. Try to find a happy medium.
Ronh
