Kawasaki 2014 Teryx T2 Spring rates.
ridepate
Does anyone out there know the rear spring rates for the Fox Podiums that come stock?? The stockers are too soft causing severe neg-camber. I absolutely hate it. Running the pre-load down to negate it just plain don't work. Or any suggestions for springs?
The negative camber is built in to the Teryx for handling.
The old body T2 with Fox RC2 shocks came with 350 pound rears. Many including myself upgraded to the 400 pound springs. I'm not sure if the suspension setup is the same as mine was a 2009
Figured it out. springs are made by Eibach. Rears are 275# T2,285#T4. Fronts are the same at 188#. Seems Kawasaki greatly reduced the rates from previous models.
