07-11 RZR RADIATOR FROM CBR PERFORMANCE PRODUCTS
CBR Performance
CBR Performance - Official UTVUnderground Sponsor
CBR PERFORMANCE PRODUCTS INC. HAS RELEASED ITS NEW POLARIS RZR 800 STAGE 1 COOLING KIT. THIS KIT FEATURES THE LATEST AND GREATEST IN HIGH PERFORMANCE COOLING TECHNOLOGY. WHAT GIVES THIS REVOLUTIONARY RADIATOR ITS EDGE IS THE CORE DESIGN, FEATURING AN ADVANCED 6.6mm FIN PITCH AND 42mm THICKNESS, COMPARED TO THE STOCK 10mm FIN PITCH AND 28mm THICKNESS. THIS ADVANTAGE ALLOWS FOR A LARGER SURFACE AREA FOR SUPERB COOLING PERFORMANCE. THE CUSTOM BUILT TANKS ALLOW A MASSIVE 20% GAIN IN COOLANT CAPACITY, AND FEATURES OUR DUALPASS DESIGN WHICH ALLOWS THE FLOW OF COOLANT TO PASS THROUGH THE CORE TWICE INHANCING THE COOLING CAPABILITY. THIS KIT IS A DIRECT REPLACEMENT, UTILIZING THE STOCK FAN AND SHROUD. THROUGHOUT TESTING, TEMPERATURES HAVE DROPPED AS MUCH AS 30 DEGREES IN THE MOST EXTREME ENVIORMENTS. DON’T LET THE HEAT SLOW YOU DOWN. THIS KIT IS 100% ALUMINUM AND 100% TIG WELDED FOR A LIGHT WEIGHT AND DURABLE CONSTRUCTION. CALL OR EMAIL FOR MORE DETAILS. TO MAXIMISE YOUR COOLING PERFORMANCE, ADD A CBR RZR OIL COOLER KIT TO YOUR ORDER.
I am heading to 747Ink tomorrow to do a full install on our new CBR Radiator for the 2011 UTVUnderground Polaris RZR4. I will post up the install pics once we are done!
I think this is going to be a great project. I have had time now to monitor engine temps when I ride and I have seen the temps jump to 220deg when running hard. I hope to be able to keep temps around 180-190 with this new Rad and Fan from CBR Performance!
